2 members (baldeagle, homer52),
36
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2010 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 54 | I found a hood support that fastens to the radiator support rod. It folds down when not in use. Roberts motor parts have them. Part # T162 for $26.50 each plus shipping. Phone # 978-363-5407. I hope this helps other bolters. This is for side open hoods. Mine is a 46.
Monroe McKill
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | For what make, year(s), models of truck?
| | | | | Joined: Jun 2010 Posts: 215 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 215 | Their website says the part fits "ALL" which probably means it doesn't fit anything well. From the looks of it they supply parts from about 1928 to 1956, so it might be a gamble to buy one, think I would talk to them on the phone first to be sure, as you may order one and then not be able to figure out how it works for your application anyways!
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Looks like it clamps on to the radiator / firewall brace rod for ( 4 ) piece hood assemblies. Rubber tip goes to the " knee joint " between top and side hoods. I have seen a couple of different versions, including home made. Would take the stress off the back corner of the side hood when open ( resting on firewall ) | | | | | Joined: Jun 2010 Posts: 215 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 215 | Kind of hard to tell looking at the website but these people are actually dodge and plymouth/chrysler suppliers. Not to mean you can't use those parts, but they don't specify GM anywhere. | | | | | Joined: Feb 2010 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 54 | Mine work real nice. Just bolt them on about the center of the rod from the firewall to the radiator and it holds the hood without danger of damage to the hood or inconvenience while working.
Monroe McKill
| | | | | Joined: Jun 2010 Posts: 215 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 215 | did you get one for both sides, or two, one for each side? Mines a 46 as well, if it works well I'm game. | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Here's an older Tech Tip that shows how to make and install hood prop. Have fun and good luck Dan | | | | | Joined: Jun 2010 Posts: 215 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 215 | Thats a really good layout and installation PDF, thanks Dan
