8 members (rfs56trk, Wally / Montana, Otto Skorzeny, Hanks custodian, FAST55, HandyAndy, 3B, Donf), 53 guests, and 2 robots.
Topics128,038
Posts1,055,584
#669054 08/09/2010 6:55 PM
With the rears done it's time to begin rebuilding the front brakes. I'm surprised that the old wheel cylinder has an inlet port that's cast at an angle. (no banjo fitting as the rear) The rubber brake line is threaded into the wheel cylinder - clipped into the frame bracket and the rigid brake ling threaded into at that point.
The new wheel cylinders are flat on the back side. Did I get the wrong parts or not enough parts?
Brian
Slinger, WI
'37 3/4 ton (grandpa)
'11 3/4 ton (grandson)
http://picasaweb.google.com/lh/photo/4xMv20nIhYF_AUPgEkRiFQ?feat=directlink
AUWING #669097 08/09/2010 10:33 PM
Ex Hall Monitor
Ex Hall Monitor
Sounds like my '38. I would say you got the wrong parts. The correct cylinders are NOT cheap. I landed two NOS cylinders on ebay for 1/4th the cost through the vendors but I had to wait a while for them to be listed. They don't show up on ebay every day. I also discovered that those listing them don't always know what they have (listing the RH as a LH and vice versa) so know what you're looking for.
Tiny #669244 08/10/2010 2:37 PM
I have found that O'Reilly's can get a lot of these parts and some of them are old stock.
Monroe McKill
Tiny #669247 08/10/2010 2:46 PM
Thanks for the response - I'll treat the original housings gently in case I need to rebuild them. Is the bore size common? (I think 1 3/8")
Did find a kit on eBay with a picture that looks correct.
Brian
Slinger, WI
AUWING #669283 08/10/2010 5:05 PM
Ex Hall Monitor
Ex Hall Monitor
If you don't mind having hoses made you can use a different cylinder as long as it fits up correctly to your backing plate and shoes. As expensive as "correct" wheel cylinders are it might be quite a bit cheaper that way.
Tiny #669346 08/10/2010 8:45 PM
Special hoses are one option. Another option I'm considering is to have banjo fittings machined. I'm a bit suprised I haven't stumbled on these as an available option.
Brian
Slinger, WI
