| | | Forums66 Topics128,052 Posts1,055,725 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 55 | With the rears done it's time to begin rebuilding the front brakes. I'm surprised that the old wheel cylinder has an inlet port that's cast at an angle. (no banjo fitting as the rear) The rubber brake line is threaded into the wheel cylinder - clipped into the frame bracket and the rigid brake ling threaded into at that point.
The new wheel cylinders are flat on the back side. Did I get the wrong parts or not enough parts?
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Sounds like my '38. I would say you got the wrong parts. The correct cylinders are NOT cheap. I landed two NOS cylinders on ebay for 1/4th the cost through the vendors but I had to wait a while for them to be listed. They don't show up on ebay every day. I also discovered that those listing them don't always know what they have (listing the RH as a LH and vice versa) so know what you're looking for.
| | | | | Joined: Feb 2010 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 54 | I have found that O'Reilly's can get a lot of these parts and some of them are old stock.
Monroe McKill
| | | | | Joined: Jan 2010 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 55 | Thanks for the response - I'll treat the original housings gently in case I need to rebuild them. Is the bore size common? (I think 1 3/8")
Did find a kit on eBay with a picture that looks correct.
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | If you don't mind having hoses made you can use a different cylinder as long as it fits up correctly to your backing plate and shoes. As expensive as "correct" wheel cylinders are it might be quite a bit cheaper that way.
| | | | | Joined: Jan 2010 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 55 | Special hoses are one option. Another option I'm considering is to have banjo fittings machined. I'm a bit suprised I haven't stumbled on these as an available option. | | |
