2 members (Stovebolt48, Southerntruck), 73 guests, and 1 robot.
Topics128,049
Posts1,055,635
#66823 10/05/2006 5:44 AM
Has anyone heard of using a 81-87 style g-body subframe(cuttlass/regal,ect.) on a 48-54 GMC/chev?
I would think it should ride pretty good..
My neighbor has one for cheap
Tony
old iron vs. new plastic....no brainer!
TECH WANTED: on S-10 frame swap
PARTS WANTED: 54 Visor, weather strips..
PARTS FOR SALE: I have complete frame / complete driveline from 54 1/2ton. very solid, will seperate
1954 GMC 3100
#66824 10/05/2006 8:44 PM
Rather that subbing your truck, why not go with the S 10 chassis swap? the S 10 has the same front suspension as the G body car, and the long bed chassis corrects the fender to wheel alignment. There also more factory upgrades (read CHEAP!) that can be done, such as 4 wheel disk brakes and suspesion upgrades. I'd leave the G body cars to the drag racers and demo guys.
Bill Burmeister
#66825 10/06/2006 4:50 AM
i cant find a short box s-10 for my 3100..
plenty of regular or long box trucks though
1954 GMC 3100
#66826 10/06/2006 5:07 AM
PM Huston54. He used a g-body subframe on his.
#66827 10/06/2006 11:02 AM
Quote
For what its worth, I don't think you want a short box s-10. I think you want a long box s-10 to match the wheelbase (116" +/-). Somebody will correct me if I am wrong.
Always get a 2nd opinion, especially if I am the source of the 1st opinion.
#66828 10/07/2006 1:46 AM
49 is exactly right: regular cab long box. The extended cab can be used if you shorten the frame which is easy and undetectable. The rear "C" channel frame transitions into the boxed front section about under the back of the cab. If you carefully cut the factory weld at this junction you can trim the rear frame to give the desired wheelbase, leave a little long to slide back into the front boxed section, and then weld exactly in the same place the factory did. In reality there are so many regular cab long box trucks available you should be able to find one.
Evan
#66829 10/08/2006 4:06 AM
i have not measured, but i thought the 1/2 ton trucks were short wheel base like the short box s-10's :confused:
and a 3/4 ton ad truck, a long box reg. cab s-10 would work.
1954 GMC 3100
#66830 10/08/2006 11:37 PM
The AD body 1/2 tons are 116" wheelbase, the 3/4 tons were 125.25". The long bed S-10 is 118", the short S-10 is 108.3", and the extended cab is 122.9".
Bill Burmeister
#66832 10/09/2006 4:02 AM
great, i put my deposit down on it.
Thanks for all the imput:)
1954 GMC 3100
