8 members (Materman, cmayna, Rusted Nut, Stovebolt48, Hugh63c10, RoadsScholar, moparguy, SNOYL),
100
Mod | | | Forums66 Topics128,070 Posts1,055,892 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 2 New Guy | | New Guy Joined: Jun 2010 Posts: 2 | My 52 has this bolt head style that I havn't seen before. They hold on everything from the rear fenders to dash board componants. The head of these fasteners looks like a bat or butterfly. They are insert type bolt and screws like allen heads. I can get pictures, no problem. And these are holding up the whole process of breakdown to begin the restoration.
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | They are called Clutch Head bolts. Drivers should be available at your local tools supplier. | | | | | Joined: Jun 2010 Posts: 2 New Guy | | New Guy Joined: Jun 2010 Posts: 2 | Thanks you guys. I live out in no where and will be in a real city tomorrow to find the drivers.
thanks | | | | | Joined: Apr 2010 Posts: 474 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 474 | I like these ,there SNAPON Clutch head bits .There great in a drill ,1/4 ratchet and apex screwdriver handle.Life time warranty about $2.55 each.part numbers are SDM242G SDM243G SDM244G SDM245G SDM246G Hope this can help. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | they do make clutch "speed bits" to use in screw guns, standard hex base, all you have to do is have a socket to fit those and you're in
Bill | | | | | Joined: Apr 2010 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 53 | thats what I figured the case would be becasue I'v never seen the bits like I was talking about.
I just hate using speed bits becasue when your on your back or twisted up under the dash and the ratchet turns the wrong way, the bit falls out, then you have to unfold out from under where ever and find the bit and try to get it to stay in while you get back folded up.lol
'54 chevy 3100. In pieces now. .... I've always liked puzzles -Gig em Aggies! Class of 2013
| | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | A tip::::::: Whenever im working up under my dash, i usually remove the bottom seat cushion, and then toss a chaise lounge cushion,or a few pillows on the floor of the truck. Try It. Your back will thank you. | | | | | Joined: Apr 2010 Posts: 474 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 474 | If you cant keep the bits in use tape ! Also the sockets with bits in them can be changed easy toother types . | | | | | Joined: Apr 2010 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 53 | good idea D54Pan . I think we have some old cushions around. The seat is no prob for me at the momonet cuz the truck is missing the entire seat frame. But being 6'3'' is my biggest limit for small places. no fix for that, grandpa said he'd put a brick on my head to keep me from gettin taller, didn't work out.....but now my head is really flat and I can rest my drink on top when working
