7 members (JW51, TUTS 59, 3800GUY, Otto Skorzeny, cmayna, 52GMC35424JD, 1 invisible), 105 guests, and 5 robots.
Topics128,065
Posts1,055,863
Members48,428
#666884 08/01/2010 6:43 PM
My 52 has this bolt head style that I havn't seen before. They hold on everything from the rear fenders to dash board componants. The head of these fasteners looks like a bat or butterfly. They are insert type bolt and screws like allen heads.
I can get pictures, no problem.
And these are holding up the whole process of breakdown to begin the restoration.
They are called Clutch Head bolts. Drivers should be available at your local tools supplier.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
It's called a "clutch head"
http://www.handtools-exporters.com/image/clutch_head.gif
"All of the forties and fifties Chevy and GMC trucks have a special type of screw/bolt called a clutch head. "
Thanks you guys. I live out in no where and will be in a real city tomorrow to find the drivers.
thanks
I like these ,there SNAPON Clutch head bits .There great in a drill ,1/4 ratchet and apex screwdriver handle.Life time warranty about $2.55 each.part numbers are
SDM242G
SDM243G
SDM244G
SDM245G
SDM246G
Hope this can help.
Stovebolt Gallery
1952 Chevy 3100
1953 Chevy 4400
1965 Nova
Pics on Photobucket
Mcmaster-Carr also has clutch tip bits in short and longer power tips. See page 2811 of their catalog. http://www.mcmaster.com/#clutch-head-screwdriver-bits/=89chip
Mike
51 Suburban
any body seen clutch head bit for a socket?
like these but clutch head?
http://i377.photobucket.com/albums/oo216/texaslocogringo/bit.jpg
'54 chevy 3100. In pieces now. .... I've always liked puzzles
-Gig em Aggies! Class of 2013
they do make clutch "speed bits" to use in screw guns, standard hex base, all you have to do is have a socket to fit those and you're in
thats what I figured the case would be becasue I'v never seen the bits like I was talking about.
I just hate using speed bits becasue when your on your back or twisted up under the dash and the ratchet turns the wrong way, the bit falls out, then you have to unfold out from under where ever and find the bit and try to get it to stay in while you get back folded up.lol
A tip::::::: Whenever im working up under my dash, i usually remove the bottom seat cushion, and then toss a chaise lounge cushion,or a few pillows on the floor of the truck.
Try It. Your back will thank you.
If you cant keep the bits in use tape ! Also the sockets with bits in them can be changed easy toother types .
Stovebolt Gallery
1952 Chevy 3100
1953 Chevy 4400
1965 Nova
Pics on Photobucket
good idea D54Pan . I think we have some old cushions around.
The seat is no prob for me at the momonet cuz the truck is missing the entire seat frame. frown
But being 6'3'' is my biggest limit for small places. no fix for that, grandpa said he'd put a brick on my head to keep me from gettin taller, didn't work out.....but now my head is really flat and I can rest my drink on top when working
Moderated by  MNSmith
