| | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | I know wipers are supposed to slow down when you climb a hill etc...mine stop as soon as I touch the gas.
My vacuum test seems good. Should they stop so easily?
I might replace my fuel pump with a dual stage to increase vacuum to the wipers.
Can I also use the dual pump to halp with vacuum brake assist?
Rich
| | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | My vac gauge reads around 21 at idle
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | I rebuilt mine and it works alot better look at the tico section of my pics it's easy and it will help get you're wipers working.
Pete | | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | Pete
I rebuit mine and it seems to work but not really any better. I have removed it once again to try to reseal it...I think it has a vac leak.
Rich
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Get it rebuilt at Fickens, or buy a new or rebuilt wiper motor. Cleaning and lubricating a vacuum wiper motor might help but most often it needs to be rebuilt (parts that wear need to be replaced). A dual-action pump should help but I have had bad luck after receiving a few dual-action pumps that had dried-out on the shelf or had been poorly rebuilt (I'll send them to be rebuilt by Fickens before buying another new or "rebuilt/remanufactured/reconditioned" one). | | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | I was able to rebuild this again and it seems to work acceptably. Thanks for the tips guys...I always learn so much on this site.
