8 members (Nick in Manitou, Jon G, baldeagle, FAST55, Hanks custodian, mick53, 50Chevy3100, Donf), 55 guests, and 2 robots.
Topics128,014
Posts1,055,332
Members48,419
#658463 06/30/2010 3:07 AM
I know wipers are supposed to slow down when you climb a hill etc...mine stop as soon as I touch the gas.
My vacuum test seems good. Should they stop so easily?
I might replace my fuel pump with a dual stage to increase vacuum to the wipers.
Can I also use the dual pump to halp with vacuum brake assist?
Rich
1953 3/4-Ton Chevy
More pix
If it can be built ... It can be fixed.
RB53
rust bucket 53 #658464 06/30/2010 3:09 AM
My vac gauge reads around 21 at idle
1953 3/4-Ton Chevy
More pix
RB53
rust bucket 53 #658466 06/30/2010 3:12 AM
I rebuilt mine and it works alot better look at the tico section of my pics it's easy and it will help get you're wipers working.
Pete
Pete52 #667984 08/05/2010 6:14 PM
Pete
I rebuit mine and it seems to work but not really any better. I have removed it once again to try to reseal it...I think it has a vac leak.
Rich
1953 3/4-Ton Chevy
More pix
RB53
rust bucket 53 #667986 08/05/2010 6:37 PM
Get it rebuilt at Fickens, or buy a new or rebuilt wiper motor.
Cleaning and lubricating a vacuum wiper motor might help but most often it needs to be rebuilt (parts that wear need to be replaced).
A dual-action pump should help but I have had bad luck after receiving a few dual-action pumps that had dried-out on the shelf or had been poorly rebuilt (I'll send them to be rebuilt by Fickens before buying another new or "rebuilt/remanufactured/reconditioned" one).
tclederman #670666 08/16/2010 2:32 AM
I was able to rebuild this again and it seems to work acceptably.
Thanks for the tips guys...I always learn so much on this site.
1953 3/4-Ton Chevy
More pix
RB53
