3 members (tclederman, TUTS 59, 1 invisible),
127
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,113 Posts1,056,279 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#66777 10/04/2006 2:00 AM | Joined: Feb 2006 Posts: 45 Junior Member | | Junior Member Joined: Feb 2006 Posts: 45 | hi i saw a lift kit for a 1955 chevy anbd was wondering would it fit on my 1951 3800?? are the frames and drive line the same thankyou derek | | |
#66778 10/04/2006 5:47 AM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy mazdabon2nd, Unfortunately that question is not an easy one to answer, you see there were two totally different 55s the first series or 55A which is basically the same as the previous years back to 48, then there is the 55 second series or 55B, so we need to know what the lift kit was engineered to fit, hope that helps more than it confuses. | | |
#66779 10/05/2006 1:18 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Where did you see the kit? The only kits I've ever seen for anything ,other then a Jeep, that was pre-'67 were custom fabbed, either by the owner or a custom 4x4 shop. I can tell you that what you probably saw was for the Second series '55, the '55-'59 Task Force body trucks have been popular lately for 4x4 conversion, namely due to the ease of adapting later axles beacause of the 34" frame width (AD trucks had tapered frames). You might look for a 4x4 shop that can fab the parts you need.
Bill Burmeister | | |
