0 members (),
125
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 39 'Bolter | | 'Bolter Joined: Jun 2007 Posts: 39 | my 55 ist series with 235 engine is non started for a couple of weeks at a time. after sitting for so long, what is the proper procedure to start the truck. sometimes it starts right up and other times i have trouble starting. thanks for any suggestions. jim | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | proper procedure: turn the key, stomp the pedal  .... no suprise if after a couple weeks the carb has evaporated it's charge, but it shouldn't need toooo much cranking to refill it - you could give it a shot of gas down the top if you want it to start faster .... in humid periods it may also be oxidizing the points a bit as well .... suggestion: drive it [or at least run it] more often Bill | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...just my .02 worth. Sometimes my 37 sits for a couple weeks or longer and when I start it I just let it spin a few times to give the oil pressure time to come up a bit and then I hit the gas pedal a time or two and it fires right up. I'm running a manual choke carb and I never have to choke it doing it the way I do...even in the winter time. Like Squeeze says, the gas evaporates and it needs to spin for a minture to get it filled back up. ( I should have explained I'm running a V8 though) | | |
