| | | Forums66 Topics128,290 Posts1,058,562 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 41 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 41 | Hey Bolters,
The pinion oil seal was leaking on my '55 first series 1 ton, so I'm in the process of replacing it. I found the proper oil seal, but the manual calls for packing to be placed inside before the seal is pressed in. I've called everywhere in town and no one carries rope seal anymore, except napa and they want $40 for three feet of it. I would prefer to avoid that since I only need about six inches. Any advice?
Thanks Bolters.
- Daniel | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | I just checked at McMaster Carr [My favorite hardware store] and it's no cheaper there.
Try a trans shop or a rear end shop that rebuilds them they may have a pc. You can buy .
Pete
| | | | | Joined: Mar 2002 Posts: 9,117 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,117 | I may be wrong here but I don't think that you use that with a modern seal. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Poly seals only need to fit the ID & OD and can float in the space for length. Any seal company will know what you need. Rope packing is just plain no good. Never had any success with it.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I'm thinking it was a felt seal in there. I believe it is listed right next to the other seal in the catalog. I havn't got my cats. at home but I can look it up tomorrow when I get to the shop. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2010 Posts: 89 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 89 | 53moneypit Is right. Repacking is old old old, school. just polish the journal where the seal rides and lube with wheel bearing grease. It should be fine.
theres a tool for every job,and that tool is a hammer. it's easy to give advice if it's not your pocket book at stake. A well thought out plan,Is nothing. Untill exacuted twice.
| | | | | Joined: Sep 2009 Posts: 41 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 41 | Thanks for the help guys. I talked to a local Jeep shop that specializes in older Jeeps and he found that the 55 first series does not need a rope or felt seal in the diff. The only manual I have is for a '54 1 ton, which is an open drive shaft, but apparently slightly different than the 55 first series. I'll come back for advice tomorrow if I still have a leaking differential.
- Daniel | | | | | Joined: Nov 2007 Posts: 12 New Guy | | New Guy Joined: Nov 2007 Posts: 12 | "New post on old thread"
I took the advise and bought a small sheet of felt from McMaster-Carr (12" x 12"), to use in my 1941 1 1/2 ton pinion axle seal. I read another post that suggested that the packing was unneccesary, but wanted to have it anyway. The thickness of the packing is 3/8" and the durometer read around 55, so I bought the 24S2 product. The part number is 8759K34. I cut it with an exacto knife and it popped right in snug. I'll post again if this fails to work like I think it will.
These tech tips are timeless. I don't post much, but I read a lot of them. Thanks for the help. | | | | | Joined: Feb 2008 Posts: 202 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 202 | Check with a marine repair shop that works on inboard boats. It is used in the stuffing box where the drive shaft goes thru the hull from the engine to the prop. It comes in different sizes.
Keep the 216's running. 1949 1/2 ton model #1314 (US 3104) Brian
