3 members (Paul_WNC, thekid1950, TUTS 59), 23 guests, and 5 robots.
Topics128,012
Posts1,055,320
Members48,419
#667400 08/03/2010 8:53 PM
Was wondering if someone might instruct me on how to remove the ignition switch? The key hole is worn out and I bought a new one from classic parts.
Thank you
fifty3 #667405 08/03/2010 9:24 PM
You will need the key to the old switch and a paper clip. Insert the key and turn it all the way to the left. Inster the paper clip into the little hole and turn the key a little bit more and pull. the cylinder will come out with the key.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Are you trying to remove the switch from the dash or remove the lock cylinder from the switch?
Cletis #667423 08/03/2010 10:18 PM
Ex Hall Monitor
Ex Hall Monitor
What Cletis said. Apples & oranges.
Cletis #667616 08/04/2010 4:29 PM
I am trying to take the cylinder out from the switch.
fifty3 #667620 08/04/2010 4:34 PM
If you have the key, I think the procedure is to press a paper clip in the small hole in the front of the barrel and then turn the key in the barrel.
tclederman #667630 08/04/2010 5:22 PM
If it won't come out you can drill them out carefully it works if you don't have the key I have had one that even with the key would not come out.
Brad Allen #667814 08/05/2010 3:46 AM
Could you elaborate on the drilling out? Just drill into the center of the cylinder?
I've removed locks from things like file cabinets that way in the past, but did not think about that for my truck. I do not have a key for the ign cylinder in my truck as the original owner could not locate them, however I have purchased a new cylinder and could not find a way to get it out without the key.
MCBIG #667840 08/05/2010 5:32 AM
Yes go down through the center it is ridged near the bottom so ease your way in carefully get all the tumblers out and it will come with a little effort.
Brad Allen #667942 08/05/2010 3:38 PM
F Online: Content
Sometimes the lock cylinder is worn enough to allow a screwdriver to act as a key and turn the cylinder. If so you may be able to do that and use the paper clip in the hole to extract the lock.
Ed
Forty9 #667999 08/05/2010 7:25 PM
LMC and others sell a new lock and body. You get a fresh start, everything new.
