| | | Forums66 Topics128,196 Posts1,057,398 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 22 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 22 | Both the remote operators (operator behind the interior door handle) are worn & sloppy. Is there a source for these units? Also how do you remove the existing units from the mounting rail? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | might check Scotts in Penhold, don't seem'em in the online list, but the remote [slot-ended rod] is reproduced so he should be able to help - otherwise one of the US vendors will have'em Bill | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Are you referring to door latch connecting link?? Check out this link.... and remember, JimCarter and American Classic are stovebolt friendly. http://www.oldchevytrucks.biz/34_46/full.asp?page=26 | | | | | Joined: Jun 2008 Posts: 22 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 22 | The connecting link connects the latch mechanism to the remote operator. The interior door handle is bolted to the remote operator.
Various vendors have a kit to rebuilt the piece of the window regulator the window crank handle bolts to but I haven't found anyone selling new remote operators or rebuild kits for the remote operators.
