8 members (wvstovebolt, 1955 1 Series, SuperSport, ‘37ChevyPU, tclederman, Gray_Ghost, Cletus1950, 78buckshot),
49
Mod | | | Forums66 Topics128,129 Posts1,056,697 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 388 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 388 | I installed my exhaust manifold after cleanup of carbon deposits. When I put it back I having a gap in one of the exhaust round to head. It doesnot go flush. Checked all the bolts are tight. I thought of buying but I cannot find anywhere.
Does that gap create backfire through carburetor. I tried to start engine and started getting backfires to carburetor.
Any information on this is appreciated
Rgds., Ganesh | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy smokey_truck, Did you remove the exhaust manifold separately from the intake or did you remove them as a unit? Did you use intake manifold alignment rings to re-install if you removed both manifolds together? Did the manifold fit fine before you removed it? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The procedure is to loosen the bolts that hold the exhaust manifold to the intake manifold. then mount the unit on the head making sure that the three alignment rings fit in and the round intake ports push up flush to the head. Do not force anything with the bolts. | | | | | Joined: Oct 2007 Posts: 388 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 388 | 3B thanks for responding, I removed intake and exhaust as one unit. I cleaned and put a new gasket and aligned intake manifold alignment rings when remounting. They were all good with no gaps when removed.
I cant find any NOS replacement. Any help is appreciated
Ganesh | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Tight bolts don't mean its aligned. I've done this myself, it took two attempts before I finally got it right! Look real close at the intake manifold, especially the under side were manifold mates up with the head. It doesn't take much of a gap to cause the problem. The alignment rings get moved out of place, and won't let the intake seat on the head! If it fit before, no reason it won't go right back on! | | |
