3 members (55shaker, Steelonsteel, Hugh63c10), 77 guests, and 1 robot.
Topics128,035
Posts1,055,552
#663134 07/17/2010 2:22 PM
Hello!
I just purchased a front sway bar set-up from a panel that I hope to adapt to my 1946 1/2-ton pick-up. The mounting to the front axle/springs is quite obivous, but I am not sure how the bar is mounted to the frame using the brackets provided.
Could anyone out there who has a panel with a front sway bar take a few reference photos for me? If so, please send them to [email protected]
Thanks in advance
Come to the Great Lakes GABfest
Get all the details here!
Randy, I am not sure if the shop repair manual has much info in it or not but I do know the assembly manual does. It may be worth the $25 bucks to purchase one.....but in the meantime see if you year is in the online manuals here.
http://chevy.oldcarmanualproject.com/
Achipmunk #663266 07/18/2010 3:23 AM
What year of panel is the sway bar from ?
Might help to determine if it will work.
1951 3100 Chevrolet
bowtietim #663585 07/19/2010 11:15 AM
U
U Offline
Original had a stud coming off the chassis, slightly ahead of the shock, this then had a bushed bar that joined the two.
Better off to get a sway bar from CPP and bolt it on to front beam, drill 3 holes in chassis - jobs a good un !
Tightens the front end up nice - does squeek a bit though !
Is this from a 55-59 Panel?
If it is and you end up not using it I would be interested in buying the Bushed Bar and Pins that connect the Sway Bar to the Chassis.
Burb'r
CHARACTER, The Only Building Project You Never Finish.
1955 2nd Series Chevy Suburban
(2) Modern Vehicles that get me around
