| | | Forums66 Topics128,034 Posts1,055,533 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2000 Posts: 163 'Bolter | | 'Bolter Joined: Dec 2000 Posts: 163 | Hello! I just purchased a front sway bar set-up from a panel that I hope to adapt to my 1946 1/2-ton pick-up. The mounting to the front axle/springs is quite obivous, but I am not sure how the bar is mounted to the frame using the brackets provided. Could anyone out there who has a panel with a front sway bar take a few reference photos for me? If so, please send them to [email protected]Thanks in advance | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Randy, I am not sure if the shop repair manual has much info in it or not but I do know the assembly manual does. It may be worth the $25 bucks to purchase one.....but in the meantime see if you year is in the online manuals here. http://chevy.oldcarmanualproject.com/ | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | What year of panel is the sway bar from ? Might help to determine if it will work. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Sep 2009 Posts: 25 New Guy | | New Guy Joined: Sep 2009 Posts: 25 | Original had a stud coming off the chassis, slightly ahead of the shock, this then had a bushed bar that joined the two.
Better off to get a sway bar from CPP and bolt it on to front beam, drill 3 holes in chassis - jobs a good un !
Tightens the front end up nice - does squeek a bit though ! | | | | | Joined: May 2009 Posts: 21 New Guy | | New Guy Joined: May 2009 Posts: 21 | Is this from a 55-59 Panel?
If it is and you end up not using it I would be interested in buying the Bushed Bar and Pins that connect the Sway Bar to the Chassis.
Burb'r -------------------------------- CHARACTER, The Only Building Project You Never Finish.-------------------------------- 1955 2nd Series Chevy Suburban(2) Modern Vehicles that get me around
