1 members (RLB), 119 guests, and 1 robot.
Topics128,110
Posts1,056,241
Members48,437
#665568 07/27/2010 5:23 PM
I have a 53 with a 216 as original equipment and plan on changing over to a 235. Does anyone know what was the different ways that Chevy mounted these two engines in 53 since that was the year they switched over? I plan on keeping mine the same and use the 216 water pump to avoid the radiator clearance problem. Is this what Chevy did in 53?
Chevy Pete
The switch was made in 54', not 53. Engines mount the same.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
In '53 the trucks used a front mount, cars used side mounts. Any later 235 (you'll want to get a '54 or later or a '53 powerglide motor for full-pressure oiling) can be converted to front mount as the engine plates are interchangable. You'll use the original 216 bell housing, flywheel, and starter (even if you're upgrading to 12V).
Read all the tech tips on this subject. You can access them at the top of this page.
To use the 216 type water pump you may need an adaptor, depending on what year 235 you are using. Search ebay for 235 water pump, the plates are always for sale and there is a good photo. Also I used the stock front mount plate on my 261 motor, and just drilled it for the old 216 mount.
1946 1/2-Ton Chevy
