1 members (Phak1),
186
Mod | | | Forums66 Topics128,110 Posts1,056,242 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 41 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 41 | I have a 53 with a 216 as original equipment and plan on changing over to a 235. Does anyone know what was the different ways that Chevy mounted these two engines in 53 since that was the year they switched over? I plan on keeping mine the same and use the 216 water pump to avoid the radiator clearance problem. Is this what Chevy did in 53?
Chevy Pete
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | The switch was made in 54', not 53. Engines mount the same. | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | In '53 the trucks used a front mount, cars used side mounts. Any later 235 (you'll want to get a '54 or later or a '53 powerglide motor for full-pressure oiling) can be converted to front mount as the engine plates are interchangable. You'll use the original 216 bell housing, flywheel, and starter (even if you're upgrading to 12V).
Read all the tech tips on this subject. You can access them at the top of this page. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | To use the 216 type water pump you may need an adaptor, depending on what year 235 you are using. Search ebay for 235 water pump, the plates are always for sale and there is a good photo. Also I used the stock front mount plate on my 261 motor, and just drilled it for the old 216 mount. | | |
