6 members (GRNHydra, Greg_H, dunfire, Ponchogl, TPR57C, stlcardinalsguy), 136 guests, and 1 robot.
Topics128,030
Posts1,055,430
Members48,422
#664229 07/22/2010 4:14 AM
What grade of fuel should I be feeding my Stovebolt 235?
50GMCguy #664234 07/22/2010 4:49 AM
I use 10% ethanol in my 261. I have the timing set right on the timing ball mark, and then turn the 'octane advance' almost all the way. It will ping if you lug it hard and will 'kick back' if you just bump the starter. I really should back the timing off a little.
If I use straight no-lead it will ping much easier.
I have never tried premium--I just can't make myself buy expensive fuel when I don't need it.
Remember 9-11-01--God Bless the USA
JUSTICE, not REVENGE, will prevail
1951 Chevy 1/2-ton Pickup truck
Racecarl #664238 07/22/2010 5:47 AM
What about using regular unleaded with a little off the shelf lead additive?
50GMCguy #664240 07/22/2010 6:04 AM
lots of folks here run unleaded without problems, including moi, in a 235 and a 283 [E10 actually] - if you get the valves done sometime, get hardened seats, but you won't have problems, the lead additive is unnecessary
squeeze #664264 07/22/2010 11:59 AM
The subject of hardened valve sets has been discussed before and the bottom line is that unless you are building a race engine it's totally unnecessary.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Czechman #664280 07/22/2010 1:30 PM
Regular gas may safely be used in 216/235/261 engine. There is no need for a lead additive (and, as Woody posted, hardened valve seats are an unnecessary pre-caution).
Woody mentions except for racing engines - I have also heard except for high-revving heavy-working engines (low speed, high-rev large trucks for example).
tclederman #664284 07/22/2010 1:39 PM
The quality of the gasoline we have available today is better than what was available when these trucks were new. They were designed to run on gas with an octane rating in the low 80's.
don stocker #664347 07/22/2010 6:21 PM
Wow I put a case of Miller Genuine Draft in the tank last night and it ran like a champ!
Thanks for the info guys, always appreciated.
50GMCguy #664902 07/25/2010 12:17 AM
just imagine how it would have run if you had put good beer in it!
'53 Chevy 3604 Five Window Cab ('56 235)
Paul's53chevy #665106 07/25/2010 10:34 PM
Well after a fresh tank of Reg Unleaded and a 20 min cruz around town im left with a cracked head and no compression in 4 out of 6. Any chance the gas had anything to do with it?
50GMCguy #665107 07/25/2010 10:35 PM
I mean 4 out of 6..
50GMCguy #665110 07/25/2010 10:43 PM
I'd say taking an engine that is knocking and smoking for a 20 minute drive had a lot more to do with it than the fuel used. Sounds to me like this engine was on it's last leg anyway. I'm betting you didn't baby it on the 20 minute drive either. Sounds to me like you wanted this engine ruined.
50GMCguy #665112 07/25/2010 10:46 PM
Pretty darn funny that all of the cars on the road today are running pretty darn good on the modern fuel.High performance and all.Engines running upward of 500 horsepower,and your old 216 sixes wont run right on the same fuel.Something not right here.My 350 CU.in my 55 and my 500 CU in. Caddy in my 65 run just fine.Oh yeah and thats on modern low grade fuel.
Cletis #665113 07/25/2010 10:55 PM
"Well after a fresh tank of Reg Unleaded and a 20 min cruz around town im left with a cracked head and no compression in 4 out of 6."
if that's what yer "left with", question is what did you start with?
answer: some burnt valves, broken rings, beer in the tank and no water in the rad
yeah, blame it on the gas, then after you spend a bundle on getting it rebuilt you'll know to never put gas in it
squeeze #665123 07/25/2010 11:33 PM
ODSS Lawman
ODSS Lawman
Ok gentleman, fuel is not the issue here.
I put 87 Octane fuel in my 261 and will drive it all day long. I will drive at speeds that most don't do in thier daily drivers.
If your running with old gas, unchecked components, and many other things, these engines will break. Pulling a truck out of where ever, changing the oil after it sat for a long time, and driving it is not an easy task for any engine.
Take that same engine, pull it apart, clean it up. Fix the other fundamentals of these trucks, and trust me, you will reach your limts before you reach the truck's.......
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
SWEET #665159 07/26/2010 2:43 AM
I did change the coolant, oil and filter, had the carb rebuilt, blew out the fuel lines, replaced the fuel and water pump, but your right I didnt do anything to this poor ol 235. Today I pulled the head and found that the pistons were hitting the intake valves. Everything was filthy and there was heavy build up everywhere. I was planning on upgrading the drivetrain anyways, its just going to have to happen sooner then later..
50GMCguy #665168 07/26/2010 3:10 AM
I think everyone should have the joy of pulling the pin and grenading an engine at least once in life. My first and only experience was a 396.....ahh, pushrods galore and the smell of burning oil.
1951 restoration on website
http://www.hanklong.com
Hankdogg #665264 07/26/2010 4:21 PM
Drove to KC last year on reg. gas 1400 miles round trip and no problems. did have fuel pump fail i think because of the alcohol in the fuel. the engine had set for 2 years while the rest of the truck was refurbished. i have put an electric pump as a backup. BTW it is a 235 with dual carbs and i ran at 70 mph all day. and averaged 20 mpg.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
WE b OLD #665324 07/26/2010 9:36 PM
Im going to have the head rebuilt and give her one more try, maybe Ill run duel carbs, thanks We b OLD.
BTW, I understand it was not the new gas that caused my valves to stick..
50GMCguy #665344 07/26/2010 11:15 PM
Head shop said it was probably the old gas that was in the tank that caused the valves to stick.
50GMCguy #665422 07/27/2010 3:52 AM
If you fired it up on old gas that is what happened. And it doesn't take long.
SWEET #665493 07/27/2010 12:38 PM
WITNESS dance cool
Cletis #665513 07/27/2010 2:14 PM
Ditto that!
Been there and done that!
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Rich'sToys #666409 07/30/2010 3:20 PM
Y
Y Offline
I drove my 49 3600 with 216 to yellowstone and back on 85-91 octane with no issues. The engine has the stock valve seats.
I used lead additive(the CD2 type) a few times early on, but then just switched to 4 oz of marvel every 3 or 4 tanks. I also put a little marvel in the air cleaner oil.
No issues
1949 Chevy 4400 Big Red
1949 Chevy 3600 Bob's Truck
1949 Chevy 3100 The Investment
1949 Chevy 3800 the Won Ton
