7 members (FAST55, TUTS 59, Wally / Montana, Wickedbass, Mike Burns, Gdads51, Donf), 85 guests, and 4 robots.
Topics128,065
Posts1,055,870
Members48,428
#66458 09/25/2006 9:51 PM
Somebody that works where I do has 2 700R4 transmissions for $150 each. Just wondering if they're worth it or not. I'm running a TH350 now, but was wondering about maybe puting one of those in. Whuddya think?
My truck: She may not be the prettiest girl at the dance, but she's all mine!
#66459 09/25/2006 10:02 PM
The 700 R4 is a good tranny, it has a lower 1rst gear than the TH350 plus the overdrive. The early ones do have a problem with a waek pump, and the throttle valve are sensitive to plugging, but other than that they are very reliable. For $150 each, I'd go for it if I was you.
Bill Burmeister
#66460 09/25/2006 10:58 PM
I love mine,,Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#66461 09/26/2006 4:33 AM
no problems with my 86 700R4... google them, and make sure you dont get the early ones, they are not as manly..
Another quality post.
Real Trucks Rattle
#66462 09/26/2006 8:28 PM
LONGBOX55 is correct about the problems with the
700R4 and there is an uprgrade kit available for them if your going to do any towing. I would recommend getting the kit just because its used.
Makeing the fix is easy and Ive done it plenty of times. Still a good transmission so go for it.
1946 Chevy 1.5-Ton Flatbed
Photobucket
Old Big Trucks are built to last.
#66463 09/26/2006 10:23 PM
Riding in the Passing Lane
I,ve done 2 of them & they are great. It,s even better when you use the lockup feature.
1972 Chevy c10 Cheyenne Super
#66464 09/27/2006 2:22 AM
1987 or later are the best ones.make sure they are v8 trans and not v6.
64 c10
89 rs
62 econoline
50 ford coupe
#66465 09/27/2006 2:45 AM
V-6 would be OK if it's from the 4.3 Chevy engine, those have the same bolt pattern as the V-8. The 60 degree V-6 and Buick V-6 are the ones that are different, and they do not match each other either.
Bill Burmeister
#66466 09/27/2006 4:10 AM
I put one in my 37 last winter and I love it. Especially the OD. It did take me awhile or several times getting in and out of the truck to get the detent cable set right for changing and downshifting....ALSO,it you are thinking about a shift kit forget it. If I don't take off easy it will spin the tires when it changes and "pop" your neck. I think this winter I will take the shift kit out. Just info...
#66467 09/28/2006 2:38 AM
i forgot about the 4.3.
64 c10
89 rs
62 econoline
50 ford coupe
#66468 09/30/2006 3:51 AM
A good core is worth $150 Another thing to keep in mind is the early 80 -85 not exact on the year had no fail safe.What I mean by fail safe is ,if the throttle valve cable is not set correctly or breaks you loose all pump pressure.What GM did was add a fail safe so if this did happen it boosts the pump pressure preventing it to shift but does'nt fry the unit from low pressure.The 88^ have better internal parts .The out put shell has a high failure rate , they strip the centers out.
By chance either of these cores 4WD units ? I'm looking for one.
In the works 2006 GEN III 6.0 /4L80E/ 205 New process,A/C and power brakes .
#66469 09/30/2006 12:33 PM
Anonymous
Unregistered
Anonymous
Unregistered
I was told my parts car(a 1989 chevy caprice) has a 700r4 in it ,how do I tell?
#66470 09/30/2006 4:58 PM
The pan is square, with one corner cut off. I think that the 700r4 was standard equipment on the late '80s Impala/Caprice.
Bill Burmeister
#66471 09/30/2006 11:21 PM
Anonymous
Unregistered
Anonymous
Unregistered
thanks bill
#66472 10/01/2006 11:34 AM
Update on the 700R4: I finally got ahold of the guy that has them. They are from 4WD trucks. Has a different tailshaft and won't work in a 2WD truck. I'll just keep my TH350. I don't have any complaints about it.
