0 members (),
106
0
Mod | | | Forums66 Topics128,101 Posts1,056,181 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#66458 09/25/2006 9:51 PM | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | Somebody that works where I do has 2 700R4 transmissions for $150 each. Just wondering if they're worth it or not. I'm running a TH350 now, but was wondering about maybe puting one of those in. Whuddya think?
My truck: She may not be the prettiest girl at the dance, but she's all mine!
#66459 09/25/2006 10:02 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The 700 R4 is a good tranny, it has a lower 1rst gear than the TH350 plus the overdrive. The early ones do have a problem with a waek pump, and the throttle valve are sensitive to plugging, but other than that they are very reliable. For $150 each, I'd go for it if I was you.
Bill Burmeister | | |
#66460 09/25/2006 10:58 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | | | |
#66461 09/26/2006 4:33 AM | Joined: Dec 2002 Posts: 3,441 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,441 | no problems with my 86 700R4... google them, and make sure you dont get the early ones, they are not as manly..
#66462 09/26/2006 8:28 PM | Joined: Sep 2006 Posts: 126 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 126 | LONGBOX55 is correct about the problems with the 700R4 and there is an uprgrade kit available for them if your going to do any towing. I would recommend getting the kit just because its used. Makeing the fix is easy and Ive done it plenty of times. Still a good transmission so go for it. | | |
#66463 09/26/2006 10:23 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I,ve done 2 of them & they are great. It,s even better when you use the lockup feature. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#66464 09/27/2006 2:22 AM | Joined: Jul 2006 Posts: 49 Member | | Member Joined: Jul 2006 Posts: 49 | 1987 or later are the best ones.make sure they are v8 trans and not v6.
64 c10 89 rs 62 econoline 50 ford coupe
#66465 09/27/2006 2:45 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | V-6 would be OK if it's from the 4.3 Chevy engine, those have the same bolt pattern as the V-8. The 60 degree V-6 and Buick V-6 are the ones that are different, and they do not match each other either.
#66466 09/27/2006 4:10 AM | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I put one in my 37 last winter and I love it. Especially the OD. It did take me awhile or several times getting in and out of the truck to get the detent cable set right for changing and downshifting....ALSO,it you are thinking about a shift kit forget it. If I don't take off easy it will spin the tires when it changes and "pop" your neck. I think this winter I will take the shift kit out. Just info... | | |
#66467 09/28/2006 2:38 AM | Joined: Jul 2006 Posts: 49 Member | | Member Joined: Jul 2006 Posts: 49 |
#66468 09/30/2006 3:51 AM | Joined: Apr 2006 Posts: 159 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 159 | A good core is worth $150 Another thing to keep in mind is the early 80 -85 not exact on the year had no fail safe.What I mean by fail safe is ,if the throttle valve cable is not set correctly or breaks you loose all pump pressure.What GM did was add a fail safe so if this did happen it boosts the pump pressure preventing it to shift but does'nt fry the unit from low pressure.The 88^ have better internal parts .The out put shell has a high failure rate , they strip the centers out. By chance either of these cores 4WD units ? I'm looking for one.
In the works 2006 GEN III 6.0 /4L80E/ 205 New process,A/C and power brakes .
#66469 09/30/2006 12:33 PM | | Anonymous Unregistered | | Anonymous Unregistered | I was told my parts car(a 1989 chevy caprice) has a 700r4 in it ,how do I tell? | | |
#66470 09/30/2006 4:58 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The pan is square, with one corner cut off. I think that the 700r4 was standard equipment on the late '80s Impala/Caprice.
#66471 09/30/2006 11:21 PM | | Anonymous Unregistered | | Anonymous Unregistered | | | |
#66472 10/01/2006 11:34 AM | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | Update on the 700R4: I finally got ahold of the guy that has them. They are from 4WD trucks. Has a different tailshaft and won't work in a 2WD truck. I'll just keep my TH350. I don't have any complaints about it.
