7 members (Otto Skorzeny, 49nut, TexasA&M48Truck, 55shaker, 3B, TUTS 59, 1 invisible),
66
Mod | | | Forums66 Topics128,089 Posts1,056,010 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 581 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 581 | Just out of curiosity, can or has anyone converted there AD or Art Deco to 4wd without a donor frame/drivetrain? Is it feasible to swap in a different axle, steering box, and a divorced transfer case? Perhaps a mild lift for clearance issues? I know the later trucks used the dealer NAPCO conversion. What did that take to accomplish. Have fun with this. | | | | | Joined: Apr 2009 Posts: 159 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 159 | I'm currently working on a 1950 Chevy that I'm making into 4-wheel-drive. Here's the short list:
1950 Cab & front sheetmetal & frame 1983 Chevy dually rear axle 1965 Chevy 292 engine 1991 Chevy 5-speed transmission & transfer case 1979 Ford F-250 front axle (because of 1991 transmission driver-side output shaft) 1979 Ford front spring assembly - much fabrication neccessary to fit to the tapered frame - essentially lifted the front of the truck 6-8 inches! '80s chevy truck steering box, power steering pump, bracketry etc. 2004 Dodge dually bed (narrowed 10.25" in width) 1974 Good Old Fashioned Yankee Ingenuity!!!
Not done yet, but getting there slowly.
Craig
It is neither wealth nor splendor, but tranquility in occupation which brings happiness. - Thomas Jefferson
CK
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | That's quite a cocktail chevoldsmoyota. How about sharing some pictures.
I have not taken any measurements or made any plans, but I have been eye-balling the early 1990's Dodge Dakota. It seems those axles are pretty close to the right width. | | | | | Joined: Apr 2009 Posts: 159 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 159 | I've got some pics from when we mocked up the bed. If I get time and can figure out this computer, I'll post them soon.
The Dakota axles would probably work great, but I'm keeping the heavy suspension under mine and plan to use it to pull a skid loader and a dump trailer.
Craig
CK
| | | | | Joined: Feb 2010 Posts: 129 Shop Shark | | Shop Shark Joined: Feb 2010 Posts: 129 | By AD do you mean art deco or advance design? Napco did make running gear for the advance design.
The Napco running gear for my truck included the front axle, new front leaf springs (one more leaf than stock), divorced transfer case (Spicer 23), and drive lines. Also some lift blocks for the rear axle, so that it sits level with the front.
Ed Miller '58 Apache short Fleetside half ton Napco Falls City, OR
| | | | | Joined: Apr 2009 Posts: 159 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 159 | Here is my photobucket album showing the bed and 4x4 mock-up. I don't think it looks too bad. The front fenders are kind of square-round with round wheel well openings, and the Dodge fenders are square-round with round wheel well openings. The front of the bed contours around the cab nicely (along the side of the cab as well as around the back of the cab!) Granted, it doesn't look vintage/stock, but I have always thought that the square bed with a rounded cab and fenders seemed incongruous. Take a look at my pictures and let me know what you think. I have thick skin, so don't be afraid to be honest! http://s605.photobucket.com/albums/tt138/capedcat/1950%20Chevy%20with%20Dodge%20dually%20bed/Thanks, Craig
CK
| | | | | Joined: Oct 2009 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 136 | I like it, one of a kind and will turn some heads.  | | | | | Joined: Nov 2006 Posts: 173 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 173 | Try looking at an early Wagoneer axles. My truck is sitting on a '63 Waggy frame and if you can adapt the axles to the stock frame, I think they should work well. I think some of the later axles will work as well, and maybe better. The later models will get you away from the closed knuckles on the front axle and will come with front disc brakes. The earlier waggys (they made a body style change in about '75 that made the axles too wide) have a track width that is close enough that you can make up the difference with rim offset. Serious Jeep types will sometimes swap out the stock axles for something stronger, though most of us will never treat our rides the way they treat theirs. These early Waggy axles have a passenger side drop so you can use a pre '88 chevy drive train.
1947, 1950, & 1952 Chevrolet 1/2 ton 1952 GMC 450 series Cab Over Engine 1946 Chevrolet 2 Ton
