8 members (Rusty Rod, TUTS 59, Peggy M, 3B, J Lucas, David Bush, Southerntruck, msmall),
122
Mod | | | Forums66 Topics128,065 Posts1,055,863 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2009 Posts: 149 | I am moving to Las Vegas from Idaho, and the wife says sell the truck. :mad: This is not good. We are getting a budget truck and I was wondering, if anyone has ever used a "tow dolley" to tow a 58 or 59 apache. If so, how did it go? Can I do it?!? | | | | | Joined: Jan 2007 Posts: 161 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 161 | rent a trailer from budget, way better. budget has nice trailers. it's a lot safer, drives a lot better. | | | | | Joined: Dec 2005 Posts: 4 New Guy | | New Guy Joined: Dec 2005 Posts: 4 | Towed a 59 longbed California to Nebraska behind a Ryder truck. 4 wheels on the ground with a bumper mounted towbar. Do not recommend this I also towed a short bed 58 behind a 3/4 ton with a 2 wheel tow dolley 200 miles. It worked fine and I would do this again. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I would get a trailer as advised. If you do it, take off driveshaft and feel wheel hubs every 100 mi. You will fling road debris/rocks at it all the way, so put up a barrier.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | There were a couple very lengthy discussions on this forum not that long ago about this very topic. The consensus was that a trailer would be the preferred way to go. | | | | | Joined: Jun 2009 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2009 Posts: 149 | | | |
