5 members (dt235sd, Toadwart, Chip O, 2 invisible), 106 guests, and 1 robot.
Topics128,087
Posts1,055,998
Members48,430
#663276 07/18/2010 4:14 AM
I am moving to Las Vegas from Idaho, and the wife says sell the truck. :mad: This is not good. We are getting a budget truck and I was wondering, if anyone has ever used a "tow dolley" to tow a 58 or 59 apache. If so, how did it go? Can I do it?!?
"Effective leadership is putting first things first. Effective management is discipline, carrying it out."
---Casey---
http://s676.photobucket.com/albums/vv127/davisears/?albumview=slideshow
rent a trailer from budget, way better. budget has nice trailers. it's a lot safer, drives a lot better.
I LOVE MY TRUCK
1959 Chevrolet Apache 38 Panel Truck in the Gallery
Towed a 59 longbed California to Nebraska behind a Ryder truck. 4 wheels on the ground with a bumper mounted towbar. Do not recommend this I also towed a short bed 58 behind a 3/4 ton with a 2 wheel tow dolley 200 miles. It worked fine and I would do this again.
Sir Searchalot
Sir Searchalot
I would get a trailer as advised. If you do it, take off driveshaft and feel wheel hubs every 100 mi. You will fling road debris/rocks at it all the way, so put up a barrier.
There were a couple very lengthy discussions on this forum not that long ago about this very topic. The consensus was that a trailer would be the preferred way to go.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Thank you.
---Casey---
