| | | Forums66 Topics128,035 Posts1,055,549 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 210 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 210 | Not sure if this should be here or paint but here go's. I want to sand and paint an extra Valve Cover for my 1946 235. It has surface rust on the inside. Once I clean it up and paint the outside, How do I refinish the inside? Does it get primed and painted or does it stay lubed from the engine oil? Thanks | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Leave inside bare and shoot it with some WD-40 to keep it from rusting. | | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | I'd suggest a bead-blast job to remove the rust, then a good pressure wash to remove any leftover beadblast media. The cover can be oiled with something more durable than WD-40 to prevent re-rusting, regular motor oil or rear end lube works well. If you choose to paint the inside, use a hot-oil-resistant paint such as Glyptal transformer paint. It's used on the inside of oil-filled electric system transformers. We've used it on race engine cylinder heads, valve valleys, and crankcases with very good success. There is no tendency to peel like Rust-Oleum or regular engine paint does when exposed to hot motor oil. W.W. Grainger used to sell transformer paint in rattle cans some time ago, but I haven't bought any recently. Start with a perfectly clean, oil-free surface to help the paint stick. Jerry
