7 members (mick53, Tiny, Southerntruck, HandyAndy, TUTS 59, 2 invisible), 82 guests, and 2 robots.
Topics128,093
Posts1,056,046
Members48,433
#662697 07/15/2010 3:17 PM
Not sure if this should be here or paint but here go's. I want to sand and paint an extra Valve Cover for my 1946 235. It has surface rust on the inside. Once I clean it up and paint the outside, How do I refinish the inside? Does it get primed and painted or does it stay lubed from the engine oil? Thanks
Leave inside bare and shoot it with some WD-40 to keep it from rusting.
1946 1/2-Ton Chevy
I'd suggest a bead-blast job to remove the rust, then a good pressure wash to remove any leftover beadblast media. The cover can be oiled with something more durable than WD-40 to prevent re-rusting, regular motor oil or rear end lube works well. If you choose to paint the inside, use a hot-oil-resistant paint such as Glyptal transformer paint. It's used on the inside of oil-filled electric system transformers. We've used it on race engine cylinder heads, valve valleys, and crankcases with very good success. There is no tendency to peel like Rust-Oleum or regular engine paint does when exposed to hot motor oil. W.W. Grainger used to sell transformer paint in rattle cans some time ago, but I haven't bought any recently. Start with a perfectly clean, oil-free surface to help the paint stick.
