2 members (ronsway, Nick in Manitou), 108 guests, and 2 robots.
Topics128,135
Posts1,056,423
Members48,441
#661346 07/10/2010 10:15 PM
I need to rewire my horn and it's the last thing electrical to do. What is the Horn relay on the firewall for? Is it for the use of more than one horn? My truck has two.
Riding in the Passing Lane
Hi neigbor. Yes it probably is there for 2 horns. The standard 1 horn on that model doesn't use a relay although it's a good idea to put one on. It should have a 10-12 gauge wire from the bat or junction going to the B term.on the relay. It should have a equally heavy gauge wire from the H term to the horns. The S term is hooked to the botton in the steering column. It can be small gauge wire. If you need help E-mail me & I might be able to swing by & take a look.
1972 Chevy c10 Cheyenne Super
Correct that there was no relay originally for thhe single horn.
Tim
Tim Sheridan
1947 First Series Chevy 1/2-Ton
"Liberty Series" - "Art Deco" - Whatever you'd like to call it.
And, only one relay would be sufficient for the accessory dual horns.
Thanks, I was only planning to use one horn. Just to clarify, if I'm only using one horn then I don't need the relay?
What style horn are you using?
I have no Idea what style horn it is. They are not original to the truck.
