| | | Forums66 Topics128,079 Posts1,056,303 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 210 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 210 | I need to rewire my horn and it's the last thing electrical to do. What is the Horn relay on the firewall for? Is it for the use of more than one horn? My truck has two. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Hi neigbor. Yes it probably is there for 2 horns. The standard 1 horn on that model doesn't use a relay although it's a good idea to put one on. It should have a 10-12 gauge wire from the bat or junction going to the B term.on the relay. It should have a equally heavy gauge wire from the H term to the horns. The S term is hooked to the botton in the steering column. It can be small gauge wire. If you need help E-mail me & I might be able to swing by & take a look. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2001 Posts: 629 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 629 | Correct that there was no relay originally for thhe single horn.
Tim
Tim Sheridan 1947 First Series Chevy 1/2-Ton"Liberty Series" - "Art Deco" - Whatever you'd like to call it. In the Gallery | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | And, only one relay would be sufficient for the accessory dual horns.
| | | | | Joined: Jan 2010 Posts: 210 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 210 | Thanks, I was only planning to use one horn. Just to clarify, if I'm only using one horn then I don't need the relay?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What style horn are you using?
| | | | | Joined: Jan 2010 Posts: 210 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 210 | I have no Idea what style horn it is. They are not original to the truck. | | |
