1 members (frogfarmer), 116 guests, and 0 robots.
Topics128,109
Posts1,056,268
Members48,439
#661788 07/12/2010 3:00 PM
I replaced the rear axle on my '57 3800 dual rear wheels with one from a '70 C30 single rear wheels to get the 4.10 ratio. The '70 axle looks identical to the '57 except for these 1 1/4" spacers on the hub.
http://i305.photobucket.com/albums/nn214/jfnar/57%20chevy%203800/DSCF1146.jpg
Here's my '57 axle. http://i305.photobucket.com/albums/nn214/jfnar/57%20chevy%203800/DSCF1147.jpg
Can these spacers be removed? Will I have to swap the drums from the '57 axle? Any advice will be appreciated.
Jeff
'64 swb stepside (gone)
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
I don't see any spacers, what I see is the hub.
The difference is the new axle has the drums mounted inboard of the hubs and the original had them outside the hubs.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
The problem I've got is that this axle is 2 1/2" wider from mounting surface to mounting surface. I guess I can swap back to the '57 axle and change pumpkins. Is there an easier way to fix this?
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
What distance do you need from mounting surface to mounting surface?
possibly a different axle or simply different hubs will solve the problem.
Also, what model axle do you have? Is it a GM "__ bolt" axle, or something different?
I found a 14 bolt that's about 62.75" for my 52 single wheel 1 ton, look here for info on it and links to measurements for other 14 bolt options
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=599879#Post599879
Grigg
---All pictures---
The '57 axle that was original to the truck is approximately 53" from mounting surface to mounting surface. The '70 axle is 55.5". I need the 53" dimension to make the rear wheel track width close to the same as the front. It doesn't look right to me now with the wider rear wheel positions. Both axles are HO72. The '57 axle has 4.56 gears and the '70 axle has 4.10 posi. I had a neighbor who was a mechanic and needed some work so I asked him to switch the pumpkins for me. He switched the entire axles instead, thinking he was doing me a favor. Sadly, he got sick shortly after doing the switch and passed away a couple of weeks ago. As the saying goes, "no good deed goes unpunished." So I guess my punishment will be to change the axles back and switch the pumpkins. What to heck; this is not a good hobby to play with if you're alergic to wrenches.
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
Sounds like you already have the solution.
Investigate your axles, hubs, and measurements to be sure swapping hubs and brakes (if possible) is not a better possibility than changing complete axle housings.
Grigg
---All pictures---
old truck heaven
old truck heaven
Most all 1967-72 Chevy 3/4ton pumpkins with fit right in the 1946-66 1-ton housing and you can use your original axels, bearings, brakes etc. I finished a swap about 5 months ago putting a 4.10 pumpkin from a 1972 Chevy 3/4 ton into a 1946 Chevy 1-ton housing....bolts right up. They must be the EATON full floating rear end.
Brian
Moderated by  Dusty53
