2 members (David Bush, 52Carl),
115
9
Mod | | | Forums66 Topics128,078 Posts1,056,029 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 8 New Guy | | New Guy Joined: Jun 2010 Posts: 8 | Everyone said to take a lot of pictures and notes but I missed a few. Plus the manuals I purchased do not show much about bed assembly. My bed had no wood when I purchase it so my question is, can you put the bed together without having the wood ready yet and anyone have pics, spec or know a good place to get them?
55 GMC 2nd Series(under construction)
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Yes, the bed can be assembled without the wood in place, just use a few peices of 1" thick board under the side angle strips to support the bed and hold in the proper hight. Mar-K would be the best place to check for a diagram on how the bed goes together. Also, the factory assembly manual is available in reprint, it has an extensive section on bed assembly.
Bill Burmeister | | | | | Joined: Mar 2009 Posts: 10 New Guy | | New Guy Joined: Mar 2009 Posts: 10 | The quick answer is "yes" you can put it together without the wood. This site is a great source for info, if you use the tech help section it will guide you to where you need to go. The biggest hassle I had was the demo part, just getting the pieces apart so you can strip down and replace all those old rusty nuts and bolts was a hassle. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | welcome to the shop katz, you've found the site for learning about your project as LONGBOX said, Mar-K is a wealth of bed info, with free downloadable booklets, but you should check out the making a bed forum here too, a Mar-K tech regularly answers questions in there Bill | | | | | Joined: Jun 2010 Posts: 8 New Guy | | New Guy Joined: Jun 2010 Posts: 8 | Thanks for all of the suggestions.
Katz
| | | | | Joined: Jun 2010 Posts: 8 New Guy | | New Guy Joined: Jun 2010 Posts: 8 | Longbox55,
I have an assembly manual (55-59). what section is the bed assembly stuff in?
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | katz - you should start at the beginning and look at every page of the assembly manual, suprising the stuff you can learn about the truck in there .... the bed assy, as indicated in the Index, is in section 1 "Platform and Pickup", the box instructions start with sheet 129.00 - note that each page references 'detail views', those are on later sheets
Bill | | |
