0 members (), 73 guests, and 9 robots.
Topics128,077
Posts1,056,033
Members48,433
Everyone said to take a lot of pictures and notes but I missed a few. Plus the manuals I purchased do not show much about bed assembly. My bed had no wood when I purchase it so my question is, can you put the bed together without having the wood ready yet and anyone have pics, spec or know a good place to get them?
55 GMC 2nd Series(under construction)
Yes, the bed can be assembled without the wood in place, just use a few peices of 1" thick board under the side angle strips to support the bed and hold in the proper hight. Mar-K would be the best place to check for a diagram on how the bed goes together. Also, the factory assembly manual is available in reprint, it has an extensive section on bed assembly.
Bill Burmeister
The quick answer is "yes" you can put it together without the wood. This site is a great source for info, if you use the tech help section it will guide you to where you need to go. The biggest hassle I had was the demo part, just getting the pieces apart so you can strip down and replace all those old rusty nuts and bolts was a hassle.
welcome to the shop katz, you've found the site for learning about your project
as LONGBOX said, Mar-K is a wealth of bed info, with free downloadable booklets, but you should check out the making a bed forum here too, a Mar-K tech regularly answers questions in there
Thanks for all of the suggestions.
Katz
Longbox55,
I have an assembly manual (55-59). what section is the bed assembly stuff in?
katz - you should start at the beginning and look at every page of the assembly manual, suprising the stuff you can learn about the truck in there .... the bed assy, as indicated in the Index, is in section 1 "Platform and Pickup", the box instructions start with sheet 129.00 - note that each page references 'detail views', those are on later sheets
