0 members (), 80 guests, and 4 robots.
Topics128,062
Posts1,055,857
Members48,428
#660069 07/06/2010 12:46 PM
One of my rear rims has a slight wobble. I don't really notice it driving however a pal of mine driving behind can see it. Is it possible to straighten the rim?
50 1/2 ton pickup (not split rims).
Too Tall #660072 07/06/2010 1:18 PM
Some of the rim seller/dealers probably can fix it. I would start with them. Check with your dirt track racers, if anybody bends rim, they would know it!
Joe
Too Tall #660073 07/06/2010 1:20 PM
Yes, you will have to fine a shop that repairs (realigns) rims. I had a set done at Stockton Wheel in CA (I could not find a local shop with a good reputation).
Too Tall #660115 07/06/2010 5:57 PM
Swap it to another location first, and check for wobble- - - -you might have a bent axle flange instead of a rim problem. If it actually is the rim, I'd try to find a replacement before wasting a lot of time and money trying to true it up.
Hotrod Lincoln #661752 07/12/2010 12:49 PM
thanks will do.
tclederman #661813 07/12/2010 4:41 PM
I too used Stockton Wheel for my MG TD. I had new tubeless type outer rims welded to the wheel centers. In 2003 it cost me $95.00 per rim + $55.00 each for powder coating. They did an excellent job & I now don't need weights on the outer rim. I highly recommend them. Charles
1937 Chevy pickup
1952 MGTD
