8 members (1955 1 Series, 39Master85, 5 Window 9434, 52Carl, Hotrod Lincoln, UtahYork, Bill Hanlon, 1 invisible), 117 guests, and 3 robots.
Topics128,089
Posts1,056,355
Members48,442
I am planning on replacing the entire set of hydraulic lifters in my 62 1/2 ton -235 c.i. engine. How do I adjust the lifters to get the engine started? Do I follow the procedures used for solids? If not how tight do I set each lifter to get the engine to start without damaging anything? Is it necessary to preload the lifters? Any suggestions will be appreciated. By the way the engine is a 55-57 truck engine that came with hydraulic lifters called a Blue Flame and is suspose to be adjusted 1 and 1/2 turns past zero clearance.
Green Machine
Edabbs,
We would always fill a coffee can with oil, put the new lifters in and let them sit overnight.
I understood this would fill them and make the rest of the adjustment more pain free.
We could always see little bubbles floating to the surface, so I assume it worked.
Stuart
I'd say to do as atomarc stated to pre-fill the lifters. Use the method for solids, but set them at 0, then re-adjust after warmup. The general concencus is that 1 1/2 turns is too much, usually 1/4-1/2 turn will suffice.
Also, I think you actually have a passenger car engine. The truck block wasn't drilled for hydraulics until '57, and even then they didn't have them until the '60s (though a few pass engines may have slipped out in trucks). The truck engines were refered to as TaskMaster, the Blue Flame was the passenger car designation.
Bill Burmeister
Thanks for the help Guys!
Green Machine
