5 members (Otto Skorzeny, 2-Ton, Wally / Montana, Lightholder's Dad, 1 invisible), 117 guests, and 0 robots.
Topics128,051
Posts1,055,730
#66163 09/21/2006 6:10 AM
Junior Member
Junior Member
I am finishing up with my 64 c10 and it was modified before my purchase. The owner removed the gas tank from behind the cab seat and extended the interior 6 inches. Now I can't find a place to put the gas tank b/c of a 78 p/u bed which is now on it. The only place I can put it is in the bed of the truck and it is exposed. I need some ideas on how to dress it up a little. I've talked to some buddies and most say to get a tonto cover or a tool box. Any other ideas to hide the gas tank, which is exposed in the bed??
Josh
1964 Chevy C10 custom
#66164 09/21/2006 1:13 PM
Put it under the bed...you'll be happier long term. I have a combination toolbox/gas tank in the bed of my truck now and removing it is my next project.
Daily Driver 63 C-10 LWB Fleetside
#66165 09/21/2006 3:19 PM
Junior Member
Junior Member
i'm running into the same problem on my '66 shortbed fleet.
looking into finding a tank to fit between diff and rear bumper, but dimensions are smaller than the tanks i've found from lmc etc.
if anyone has an interchange part number/application or vendor suggestion i'd be interested in the info.
bill graham
#66166 09/21/2006 4:08 PM
Look for a Suburban tank. Anything up to an '87.
The frames from '60 to '87 are essentially the same.
Locate the tank at the very back of the frame under the bed. Run the filler neck up in to one of the wheel wells and you're done.
__________________
Guy
Tractor78
Stovebolter# 11275
__________________
#66167 09/21/2006 5:04 PM
The 67-72 burb tank is a bolt-in, American Classic sells the whole setup $200+, includes the sending unit for 60-66(30ohms)fits like a glove. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#66168 09/22/2006 5:52 PM
Does American Classic include the straps?
_________________
Guy
Tractor78
Stovebolter# 11275
__________________
