2 members (2-Ton, JW51),
67
Mod | | | Forums66 Topics128,055 Posts1,055,783 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#66163 09/21/2006 6:10 AM | Joined: Apr 2006 Posts: 5 Junior Member | | Junior Member Joined: Apr 2006 Posts: 5 | I am finishing up with my 64 c10 and it was modified before my purchase. The owner removed the gas tank from behind the cab seat and extended the interior 6 inches. Now I can't find a place to put the gas tank b/c of a 78 p/u bed which is now on it. The only place I can put it is in the bed of the truck and it is exposed. I need some ideas on how to dress it up a little. I've talked to some buddies and most say to get a tonto cover or a tool box. Any other ideas to hide the gas tank, which is exposed in the bed??
Josh 1964 Chevy C10 custom
#66164 09/21/2006 1:13 PM | Joined: Nov 2005 Posts: 248 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 248 | Put it under the bed...you'll be happier long term. I have a combination toolbox/gas tank in the bed of my truck now and removing it is my next project. | | |
#66165 09/21/2006 3:19 PM | Joined: May 2006 Posts: 35 Junior Member | | Junior Member Joined: May 2006 Posts: 35 | i'm running into the same problem on my '66 shortbed fleet.
looking into finding a tank to fit between diff and rear bumper, but dimensions are smaller than the tanks i've found from lmc etc.
if anyone has an interchange part number/application or vendor suggestion i'd be interested in the info.
bill graham
#66166 09/21/2006 4:08 PM | Joined: May 2006 Posts: 63 Member | | Member Joined: May 2006 Posts: 63 | Look for a Suburban tank. Anything up to an '87.
The frames from '60 to '87 are essentially the same.
Locate the tank at the very back of the frame under the bed. Run the filler neck up in to one of the wheel wells and you're done.
__________________
Guy Tractor78 Stovebolter# 11275
__________________ | | |
#66167 09/21/2006 5:04 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | The 67-72 burb tank is a bolt-in, American Classic sells the whole setup $200+, includes the sending unit for 60-66(30ohms)fits like a glove. Brian | | |
#66168 09/22/2006 5:52 PM | Joined: May 2006 Posts: 63 Member | | Member Joined: May 2006 Posts: 63 | Does American Classic include the straps?
_________________
