0 members (), 151 guests, and 1 robot.
Topics128,089
Posts1,056,141
Members48,436
#661278 07/10/2010 4:28 PM
The rear spring perch on the back of my 55 pickup has a threaded hole that the spring shackle "bolt" threads into. That threaded hole in the spring perch is stripped. Does anyone know of a fix for this? Is there a threaded sleeve in there that can be replaced? If so any suggestions for where i would find one? If necessary I can grind the rivets out and have a machine shop make me a threaded sleeve to press into it. But that's a last resort.
Are you talking about the spring hanger or the spring perch? The perch prevents the axle from rolling, it acts like a chair for the axle to sit on. The spring hanger is rivoted to the frame. There is a threaded bushing that is pressed into the spring hanger to accept that threaded pin. You may try getting a new spring shackle kit at NAPA or one of the suppliers. The shackle comes with 2 new pins and 2 new bushings.
Sorry I didn't communicate that properly. I did mean the spring hanger. I wasn't sure if there is a threaded bushing pressed into it. Thanks for your help
