| | | Forums66 Topics128,087 Posts1,055,985 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 9 New Guy | | New Guy Joined: Mar 2010 Posts: 9 | The rear spring perch on the back of my 55 pickup has a threaded hole that the spring shackle "bolt" threads into. That threaded hole in the spring perch is stripped. Does anyone know of a fix for this? Is there a threaded sleeve in there that can be replaced? If so any suggestions for where i would find one? If necessary I can grind the rivets out and have a machine shop make me a threaded sleeve to press into it. But that's a last resort. | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Are you talking about the spring hanger or the spring perch? The perch prevents the axle from rolling, it acts like a chair for the axle to sit on. The spring hanger is rivoted to the frame. There is a threaded bushing that is pressed into the spring hanger to accept that threaded pin. You may try getting a new spring shackle kit at NAPA or one of the suppliers. The shackle comes with 2 new pins and 2 new bushings. | | | | | Joined: Mar 2010 Posts: 9 New Guy | | New Guy Joined: Mar 2010 Posts: 9 | Sorry I didn't communicate that properly. I did mean the spring hanger. I wasn't sure if there is a threaded bushing pressed into it. Thanks for your help | | |
