| | | Forums66 Topics128,099 Posts1,056,499 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 158 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 158 | I wouls like to know if there are any frame mounted brake booster kits. For a 1946 chevrolet 3/4 ton truck that will mount in the factory location of the old master cylinder. I have looked at all the links on the stovebolt site but I havent had any luck because they are all for 1947-1955 model trucks. I would also like to know if there are any universal frame mounted brake booster kits out there that cand be adapted to my truck and also to the push rods that come with some of the kits thread into the master cylinder like the original from the factory. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Oldtrucks....no promises here but you may want to check out PirateJacks.com in asheville,N.C. 866-601-4455 tell Tammy that Alvin said to call her. They are distributor for MBM which is were lots of these kits come from. I don't have their web address handy. Their prices seem good compared to most...for the same stuff!! | | | | | Joined: Nov 2000 Posts: 1,969 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,969 |
Professional Novice
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Thanks for correcting that Frank. My goof...I promise to do better. | | |
