3 members (TUTS 59, carbking, dunfire), 62 guests, and 5 robots.
Topics128,179
Posts1,057,161
Members48,465
What is the number of steering wheel revolutions lock to lock on a 1954 3100?
I looked in the Service Manual and Searched for it here in the Forum.
I can check mine tonight if you don't get an answer.
I did see that prior my post, but I can't see where it tells the number of steering wheel revolutions lock to lock.
I believe it's about 2 1/2 to 2 3/4, somewhere in there. I rebuilt my steering box and reset everything when putting it back together. Had a hell of a time finding center.
I'll give you information for my 55 first series. Bump to bump is 4-1/8 revolutions.
sfsutton, I was curious so I check my 54 3100... From center just under 2 1/2 turns left to the bump, and just under 2 full turns to the right to the bump... What is up with the 1/2 turn difference? When I looked at OldSub Steering gear link and looked at the Turning Diameter chart, it shows "A" diameter range being Max 41-39 1/4 Min and "B" diameter range being Max 43 1/2-41 3/4 Min... This would explain the 1/2 turn difference...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
See step #4 and onwards,
It should be set in the middle (no matter how many total turns it is from side to side).
My 1952 3100 has just over 4 1/2 turns without the pitman arm attached.
Chuck
Thanks so much for your replies. Stupid me, I'm doing a front disc brake install and I didn't check to see what the revs were before I started. "I thought" I had that information tucked away.
I'm all set now....till the next thing.
