1 members (tclederman),
94
Mod | | | Forums66 Topics128,181 Posts1,057,185 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 150 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 150 | What is the number of steering wheel revolutions lock to lock on a 1954 3100?
I looked in the Service Manual and Searched for it here in the Forum.
Thanks | | | | | Joined: Mar 2010 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 119 | I can check mine tonight if you don't get an answer. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 |
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Feb 2006 Posts: 150 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 150 | I did see that prior my post, but I can't see where it tells the number of steering wheel revolutions lock to lock. | | | | | Joined: Sep 2008 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 137 | I believe it's about 2 1/2 to 2 3/4, somewhere in there. I rebuilt my steering box and reset everything when putting it back together. Had a hell of a time finding center. | | | | | Joined: Jan 2008 Posts: 176 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 176 | I'll give you information for my 55 first series. Bump to bump is 4-1/8 revolutions. | | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 | sfsutton, I was curious so I check my 54 3100... From center just under 2 1/2 turns left to the bump, and just under 2 full turns to the right to the bump... What is up with the 1/2 turn difference? When I looked at OldSub Steering gear link and looked at the Turning Diameter chart, it shows "A" diameter range being Max 41-39 1/4 Min and "B" diameter range being Max 43 1/2-41 3/4 Min... This would explain the 1/2 turn difference...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | See step #4 and onwards, It should be set in the middle (no matter how many total turns it is from side to side). | | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | My 1952 3100 has just over 4 1/2 turns without the pitman arm attached.
Chuck | | | | | Joined: Feb 2006 Posts: 150 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 150 | Thanks so much for your replies. Stupid me, I'm doing a front disc brake install and I didn't check to see what the revs were before I started. "I thought" I had that information tucked away.
I'm all set now....till the next thing.
Thanks | | |
