0 members (), 105 guests, and 3 robots.
Topics128,194
Posts1,057,261
Members48,466
I decided to buy a new galvanized gas tank for the 57 3100 pickup. In the past I have had issues with gas smell and wet appearance around the sending unit. Since I had it all out for a wiring harness replacement and painting the inside of the cab I figured I would finally just replace the gas tank.
When I install the new galvanized tank and sending unit is there some special sealant or gasket prep I need to use or does the gasket go on dry?
The Assembly Manual says "4 see Lubrication Instruction - Section 14" But I do not see anythign listed for the sending unit in section 14 pages 9, 10 and 11.
The old tank was dry on the side of the rubber gasket (on top) where the sending unit mounts on top of it.
But the gasket had some sort of cement on the bottom of it to the tank. It was slathered all over the tank and down the back of it and around the edges of the gasket but none on the top of the gasket. I was able to pull it off in one or two pieces revealing a shiny tank below it.
So what is the proper way to assemble the tank, gasket and sending unit so that it has no chance of leaking?
Also, Should I paint the tank or not?
If I paint it should I have the sending unit instaled before painting it so that there is no paint under the gasket?
If the tank is galvanized then it don't need painting. As someone mentioned in another post IF you do paint it rinse it with vinegar. I personally would leave it along.
There should be no need to put something under a new gasket as long as its tightened properly. Some gaskets are cork, some are rubber. Most re-pop are rubber unless you order the cork ones. Just depends on the site/vendor.
I don't think paint, one way or the other would hurt as there is no gas getting to the paint unless the sender is not tight. But, if you paint, it could effect the ground which is the most common problem with guages these days.
In short, I'd not paint the tank or sender and I would make sure all/any connections are tight with new seals/rubber. A new gas cap is also in order. You should not have a gas smell problem.....except maybe right after you fill up for a minute or two.....all this is my opinion, and what I do with new tanks.
Whew, this got to long.
Thanks for your input.
That makes the process a bit easier. no paint and no dressing/sealant/cement for the gasket.
