2 members (51sub, Possum), 113 guests, and 4 robots.
Topics128,265
Posts1,058,364
Members48,485
#660225 07/07/2010 1:40 AM
U
U Offline
Hi all,
Can someone tell me how to check to see if my tie rods are shot on my 1957 3100 Chevy 1/2 ton?
I called NAPA and they no longer carry them. Can I still get them made in USA? I know I can get them at Filling Station and other after market places...But I have a feeling they are made in China
Thanks!
Jon
1957 Chevy 1/2-Ton Truck
More pix
The coldest winter I ever saw was a summer I spent in San Francisco M. Twain
If at first you don't succeed...skydiving is not for you!
If you don't like my carbon foot print, stick it up your Prius!!
UnklRod #660230 07/07/2010 1:56 AM
unlikely the tie rod is shot, unless it's obviously bent [or has a piece of angle welded to it because it was bent] - have someone rock the steering wheel back and forth [stopped!] while you watch underneath - just look for excess slop without any wheel movement .... might need some of the joints replaced, like the tie rod ends ... don't worry about imported, they'll work
squeeze #660349 07/07/2010 12:20 PM
NAPA online list them $100 ea. Just plug in your vehicle info.Take the part number to your local NAPA dealer and they can order them for you.
www.napaonline.com
Drew
DrewP #660379 07/07/2010 2:51 PM
Rock Auto has the ends for $36 & change. They are Raybestos brand.
www.rockauto.com
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
53moneypit #660523 07/07/2010 11:30 PM
U
U Offline
I can tell mine are shot....Just placed order with Rockauto.
Thanks all,
More pix
UnklRod #661700 07/12/2010 4:40 AM
U
U Offline
Hi all,
I have a feeling I do not have the style of the " round " looking tie rod ends.
These are what I have. Also, how can I repair the drag link or connecting rod for the pitman arm and left spindle?
More pix
UnklRod #661705 07/12/2010 5:03 AM
Jon,read this tech tip tie rods I used a 9/16" drill bit and drilled 1/8" to 1/4" deep with the drill.I then chucked the pieces up in my vise and heated with a torch,used a big punch and hammer to drive the balls out.make sure you use the straight threaded tie rod studs and not tapered.There is all kinds of info about this subject here.
1951 3100 Chevrolet
bowtietim #662634 07/15/2010 8:48 AM
U
U Offline
Looks like I am unable to re-use my old tie rods. Can someone tell me how you change to the new ones? I have my new tie rods
More pix
UnklRod #662694 07/15/2010 3:11 PM
why plural? you meaning the ball ends? the procedure is in the shop manual [note right and left threads], and you'll need steering aligned afterward .... also the drag link is replaced, not repaired, NAPA should have the complete thing
squeeze #662757 07/15/2010 7:43 PM
U
U Offline
Bill,
Thank you! Yes, I got the last drag link on the west coast from Napa. Thank you for the link to the manual page. Did not look hard enough. Will get it done now the right way.
Thank you as always for the help!
Jon
More pix
