0 members (),
68
8
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Hi all, Can someone tell me how to check to see if my tie rods are shot on my 1957 3100 Chevy 1/2 ton? I called NAPA and they no longer carry them. Can I still get them made in USA? I know I can get them at Filling Station and other after market places...But I have a feeling they are made in China
Thanks!
Jon
1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | unlikely the tie rod is shot, unless it's obviously bent [or has a piece of angle welded to it because it was bent] - have someone rock the steering wheel back and forth [stopped!] while you watch underneath - just look for excess slop without any wheel movement .... might need some of the joints replaced, like the tie rod ends ... don't worry about imported, they'll work
Bill | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | NAPA online list them $100 ea. Just plug in your vehicle info.Take the part number to your local NAPA dealer and they can order them for you. www.napaonline.com
Drew
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Rock Auto has the ends for $36 & change. They are Raybestos brand. www.rockauto.com | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | I can tell mine are shot....Just placed order with Rockauto. Thanks all,
1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Hi all, I have a feeling I do not have the style of the " round " looking tie rod ends. These are what I have. Also, how can I repair the drag link or connecting rod for the pitman arm and left spindle?
1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Jon,read this tech tip tie rods I used a 9/16" drill bit and drilled 1/8" to 1/4" deep with the drill.I then chucked the pieces up in my vise and heated with a torch,used a big punch and hammer to drive the balls out.make sure you use the straight threaded tie rod studs and not tapered.There is all kinds of info about this subject here. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Looks like I am unable to re-use my old tie rods. Can someone tell me how you change to the new ones? I have my new tie rods
1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | why plural? you meaning the ball ends? the procedure is in the shop manual [note right and left threads], and you'll need steering aligned afterward .... also the drag link is replaced, not repaired, NAPA should have the complete thing Bill | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Bill, Thank you! Yes, I got the last drag link on the west coast from Napa. Thank you for the link to the manual page. Did not look hard enough. Will get it done now the right way. Thank you as always for the help!
Jon 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | |
