| | | Forums66 Topics128,065 Posts1,055,868 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2009 Posts: 49 | One of my rear rims has a slight wobble. I don't really notice it driving however a pal of mine driving behind can see it. Is it possible to straighten the rim?
50 1/2 ton pickup (not split rims). | | | | | Joined: Feb 2000 Posts: 5,206 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,206 | Some of the rim seller/dealers probably can fix it. I would start with them. Check with your dirt track racers, if anybody bends rim, they would know it!
Joe | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Yes, you will have to fine a shop that repairs (realigns) rims. I had a set done at Stockton Wheel in CA (I could not find a local shop with a good reputation). | | | | | Joined: Feb 2004 Posts: 29,776 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,776 | Swap it to another location first, and check for wobble- - - -you might have a bent axle flange instead of a rim problem. If it actually is the rim, I'd try to find a replacement before wasting a lot of time and money trying to true it up. Jerry
| | | | | Joined: Jun 2009 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2009 Posts: 49 | | | | | | Joined: Jul 2002 Posts: 166 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 166 | I too used Stockton Wheel for my MG TD. I had new tubeless type outer rims welded to the wheel centers. In 2003 it cost me $95.00 per rim + $55.00 each for powder coating. They did an excellent job & I now don't need weights on the outer rim. I highly recommend them. Charles | | |
