Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (klhansen, NJC, UnclePaddy, Guitplayer, 1955 1 Series), 88 guests, and 3 robots.
Topics128,281
Posts1,058,460
Members48,490
#65978 09/18/2006 4:01 PM
Junior Member
Junior Member
i can get it started but it wont stay on fuel pump is pumping what else could be the prob i have no idea what im doing
#65979 09/18/2006 4:22 PM
gvictor4,
Could you explain a little bit more...everyone would love to help you.
Is this truck still 6 volts or has it been changed to 12 volts?
Will it start great every time, but won't idle?
How about if you keep pumping the gas pedal, will it try to run?
Tell us exactly what happens.
Stuart
#65980 09/18/2006 10:56 PM
Riding in the Passing Lane
If you have a 12 volt system there is a ceramic resister on the fire wall. If it is burned out or not getting current from the ignition switch it will cause this problem. Use a test light & turn on the ign. switch. You should have current at both terms. of the resister & the pos. term of the coil.
1972 Chevy c10 Cheyenne Super
#65981 09/19/2006 7:07 AM
Junior Member
Junior Member
6 volt and i have to put gas in the carb to turn on i checked the pump and its pumping i think maybe the choke but dont know how that works in or out for on i pull on the gas at the carb and it tryes but no dice any more info you guys need ill be messing with it tomorrow all day with my laptop next to me just let me know
#65982 09/19/2006 2:53 PM
Has this truck been running recently, or has it been sitting for a year or more?
1. Are the points gapped correctly? Are they new or old?
2. Are the plugs fouled or clean?
3. Is the timing set correctly?
4. Is the carburetor float level set correctly?
5. Is the Johnson rod been recently calibrated?
#65983 09/19/2006 3:26 PM
gvictor4,
It sounds like it is a fuel issue if it will start every time but won't keep running. Is there a fuel filter on it that could be plugged.
If you take the fuel line off at the carburetor, it should gush gas as you turn the motor over. Be sure to do this into a cup or pan..no fires.
You know you have gas in the tank...could you have any water in the gas?
Keep trying and let us know, we will figure it out with you, or die trying. grin
Stuart
#65984 09/19/2006 3:52 PM
Junior Member
Junior Member
no filter between pump and carb.fuel does gush out tryed to stop it with finger didnt work.
it has been sitting for about a year.points are new.plugs are clean,new.everything else i dont know how to do exept for the johnson rod i have no idea what that is
#65985 09/19/2006 4:15 PM
gvictor4,
If the rig starts and has lots of fuel up to the carburetor, it sure sounds like it is the carburetor itself.
Just for grins, rap on the side of the carburetor with a screwdriver handle. You might wake up a stuck float.
If you can do it VERY carefully, try and keep the truck running by pouring little amounts of fuel down the carburetor after you get it started.
This will tell you every other system is working except the fuel system. Be very careful with the gas ...a backfire could cause havoc.
Pay no attention to the Johnson rod remark, it was said in jest.
Good luck and keep a wet towel handy for fires!
Stuart
#65986 09/19/2006 7:13 PM
Junior Member
Junior Member
I have the same problem with my '63. It will turn over but as soon as the key is let go it won't rev.
#65987 09/19/2006 7:38 PM
wadatah5,
As 'wrenchbender' hinted at above, if your rig is a 12 volt system, and you have a ballast resistor in the primary lead wire, this is a "classic" failure.
The ignition system is powered in the START position, but because there is an open in the resistor, it is dead once the key returns to RUN.
This is a obvious scenario, but it isn't the same as the truck actually starting, running and fizzling out...that is a different animal.
Stuart
#65988 09/19/2006 7:44 PM
my 350 is doing the same thing... but it sat in the desert sun for 4 years... it fires right up, and will only keep running after i've poured gas into the carb about 20 times... i opened the carb and it's all gummed up.
Another quality post.
Real Trucks Rattle
