| | | Forums66 Topics128,192 Posts1,057,350 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 36 Apprentice | | Apprentice Joined: Aug 2009 Posts: 36 | Ok, need some help. I finally got the front end tore apart of my 57 3100. Can anyone tell me if I have the original parts, or send me somewhere to find out. Thanks ahead of time.
Engine - No ID next to the distributor, this worries me, but under the distributor on the block reads #6764476
Intake # 3885527 Head # 3836848 Transmission # 3846167GM
The plate on the inside panel gives a Trim code of PPO 431A, and the Paint code of # 769. I believe this to be red with white around the window. I appreciate your help. This will determine whether to keep it stock or resto mod.
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | look for date codes, not casting numbers, those covered a range of years
no number on the pad by the dist likely means it was rebuilt, why worry? do you really think that a 53 year old truck has never had any engine work? .... that makes it not worth keeping original?
don't know of any info available on the trim #'s, but the 761 is cardinal red - not a 2 tone, but trim color would be bombay ivory
| | | | | Joined: Aug 2009 Posts: 36 Apprentice | | Apprentice Joined: Aug 2009 Posts: 36 | thanks Bill, I searched and these are the numbers I could find. My lack of experience finding and knowing where to look for on date codes has me scratching my head. I will look through again today. Basically I wanted to make sure it was correct engine. | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | The date code on a 235 will be a letter followed by 2, or 3 numbers and is located on the block just above the starter. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Correct and original are really two different things. It could still have the original motor but if the truck has seen many miles its most likely been rebuilt or replaced.
If its been rebuilt it is still original. If its been replaced it may still be correct, but it isn't original.
Now if you will accept my definitions at face value, and not all do, what do you really have? There is no registry that lists what motor came in what truck and no way beyond coincidence of showing the motor belongs in the truck. There can be many ways to show it didn't start life there.
I tend to evaluate a little differently. If its going to require a lot of work to make it look original I don't care how original it really is, I go whatever direction my pocket book and whims take me. If its likely a clean and easy return to original I'm like to consider that route, knowing its not what I want but could be easy to turn for more project money.
I've never completed a restoration, but is because I rarely buy stuff I don't see as hot rod material.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 | With the "No ID next to the distributor" the engine may have been replaced... On my 54 3100, the original engine that I thought came from the factory turned out not to have any ID numbers next to the distributor... So I am thinking it was also replaced...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
| | | | | Joined: Aug 2009 Posts: 36 Apprentice | | Apprentice Joined: Aug 2009 Posts: 36 | Thanks for all the feedback. I really appreciate it. | | |
