0 members (), 107 guests, and 2 robots.
Topics128,265
Posts1,058,365
Members48,485
#65886 09/17/2006 3:37 AM
The "3 on the tree" gearshift on my 52 3100 rattles quite a bit.
It seems to be worn where the shift lever connects to the rod that runs down the steering column. How can I remove the lever? Can you buy parts for whatever is worn in there? What are the parts called?
My dad always told me, "Don't force it, get a bigger hammer".
#65887 09/17/2006 6:41 AM
There are two spring loaded pins that hold the lever onto the column. The actual shift lever rod has a ball on the end that fits inside the shift lever, maybe that's where the rattle comes from. Lots of parts on an old truck are worn so chasing rattles might be a full time job.
#65888 09/17/2006 6:56 AM
yer lookin for "Shift lever retaining pins, spring and rubber bushings" here , and maybe even the mounting piece that screws to the column
#65889 09/18/2006 10:08 PM
Thanks for the info, guys.
You're right about chasing the rattles. For some reason, this one bothers me - maybe because it's right under my nose.
#65890 09/19/2006 4:32 AM
Apprentice
Apprentice
Try to get by with out the Gear shift collar new ones want fit right & your old one may be ok also the two bolts that hold it on are a rare size do not lose them.
Thanks, Kelly
53 3100
http://www.cravy.com/53-3100/LadyAfterRats.jpg
