| | | Forums66 Topics128,012 Posts1,055,315 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#65873 09/16/2006 11:28 PM | Joined: Jul 2006 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 163 | This may seem like a dumb question but thought I should ask. I just recently purchased a new fuel pump for my 51 1/2 ton. This new pump looks as if it will be put in upside down compared to the one that is currently on the engine. Does the line from the gas tank have to be bolted to the inlet side of the pump that says "IN". Or, does it make a difference. :rolleyes: If so, they sold me the wrong pump. | | |
#65874 09/16/2006 11:39 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Jon D,
The supply must be connected to the suction side of the fuel pump. If yours is stamped IN...it leaves no doubt.
It isn't crystal clear which end is up on these pumps...are you sure you have the wrong one.
The pump lever points UP, and if yours has a glass bowl, it probably makes it on top. To my knowledge, this is the correct orientation for the pump.
Internal valves make it direction sensitive.
Stuart | | |
#65875 09/16/2006 11:56 PM | Joined: Jul 2006 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 163 | atomarc,
Thanks for replying. I think I have it figured out. Tell me if I'm correct, the pump lever should be pointing up (which means the "IN" inlet would be on the gas tank side) and the outlet would be from the pump to carb. I think what had me confused is that this 235 engine (from a 1955 model) does not have a push rod. Correct? Other old vintage cars I worked on had a push rod. Also, where can I purchase a glass see through fuel filter, I think I need one of those also. | | |
#65876 09/17/2006 12:03 AM | Joined: Jul 2006 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 163 | This one does not have a glass bowl. | | |
#65877 09/17/2006 12:23 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Jon D,
You are correct...no pushrod, just a lobe on the cam.
For a glass filter bowl, you might try your local auto parts store, or maybe American Classic, which is the sponsor of this great site.
They have a flashing icon on top of this page..just click and enter. Good luck.
Stuart | | |
