| | | Forums66 Topics128,189 Posts1,057,337 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#65828 09/16/2006 5:30 AM | Joined: Jul 2005 Posts: 52 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 52 | My 51 stovebolt has been converted to a 235 w/ a T-5 tranny. About 10,000 trouble free miles since being converted
Recently makes noise only when the clutch is depressed. Inspected the situation & found my release bearing up against my clutch all the time with no free play. I figured it wore itself out so I had the bearing replaced. Pilot bearing was inspected & found to be ok.
All back together...50 miles later the noise returns....intermitent.
I'm stumped...don't know what to check next?
Any help will be appreciated.
Thanks | | |
#65829 09/16/2006 7:00 AM | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | Have you re-adjusted the clutch since the t/o bearing install? Is the release bearing touching now?
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | |
#65830 09/16/2006 11:33 PM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | From what I've read (I've never done a T-5 yet)you have to grind the splines further back towards the transmission so the T.O. bearing slides far enough back to not be in constant contact with the pressure plate. Maybe that's the reason for your premature wear, Scott | | |
#65831 09/17/2006 2:01 AM | Joined: Apr 2006 Posts: 159 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 159 | I have seen the bronze pilot bushing make all kinds of noise with the clutch depressed.It's trying to gauld the pilot bushing to the imput shaft.I have read alot of the guys and gals on the forum that don't like the roller pilot bearing but it will resolve an issue like this.I have never installed a T-5 but I would guess this could be your issue.Try it you might like it?
In the works 2006 GEN III 6.0 /4L80E/ 205 New process,A/C and power brakes .
