1 members (IHPWR),
117
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,162 Posts1,056,940 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 388 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 388 | I need some advise, I have stripped the complete truck to bare metal, painted the engine. Is it common to paint the firewall black like the one eastwood sells underhood black. I am not sure about color, and do not know about my ability to shoot the quality color properly but I need to keep moving as my garage lease is until September and need to get truck running. so I want to assemble the truck with primer and decide on the color and want to be able to drive the truck to paint shop if needed. Want to complete the engine area, primer and assemble the truck.
Any advise will help please?
Ganesh
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Make, model, year of truck? | | | | | Joined: Oct 2007 Posts: 388 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 388 | | | | | | Joined: Oct 2009 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 40 | I went with black, but then again I painted my truck black so it was easy. I would paint it a dark color for sure something you can keep clean easy. I'm not one for painting the firewall the same color as the rest of the vehicle, even on my truck I painted it semi gloss black. | | | | | Joined: Apr 2008 Posts: 203 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 203 | If you're going original, I think the firewalls were cab color.
Dave
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | As Dave correctly stated, the 47-55 Chevrolet cab-firewall was painted body color on the engine side. The inner fenders, radiator/radiator-frame, frame-to-firewall brace-bars were a semi-gloss black.
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Whatever colour you choose, best to get final coat on while you can get at it. Difficult to finish nicely after motor installed. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...just another thought. On my panel I painted it body color down to where it started to "taper back/down". You can see what it looks like just as a body or with the engine in at my photobucket below. Hope this helps. | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | I suggest you decided on a color and paint the firewall that color. If you just can't do that, then paint it black since it will go with just about any color.
